Jabber Directory Search over MRA
ShankarP
Hi experts, one of our clients had requirement to perform contact search using Department/Title, we manage to get it work using the parameter "PredictiveSearchFilter" in Jabber config file. The deployment uses MS Active directory. The Predictive search filters does not seem to work over MRA. Are we missing any config or is there a way to make it work? Thnx
Anurag Srivastava1
I think its not supported over MRA. Please check the below link (under page 15 Known Unsupported Client and Endpoint Features )
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X12-5/Mobile-Remote-Access-via-Expressway-Deployment-Guide-X12-5.pdf
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
George Sotiropoulos
Unfortunately, this is not -currently- supported over MRA as you may check below:
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
