Jabber MRA Call drop
MuhammadSaad_2
Dear
When we call from Jabber client (MRA) to any PSTN number its just half ring and drop.
If we call internal extension or other Jabber client it work fine.
Kindly help its urgent.
Thank You
Muhammad
OK pls quickly try this..
On your h323 gateway in CUCM enable out bound fast start. Ensure that you have mtp resource to do outbound fast start. Reset the gateway after enabling this and test again
Please rate all useful posts
7 Replies 7
Ayodeji Okanlawon
There is no quick fix to issues like this without detail troubleshooting.
What do you use for PSTN access? Sip?  ISDN? expressway issues are complex to troubleshoot.. We need to look at cucm logs , expwc logs, gateway logs..
Hi Muhammad.
We need some info from you in order to troubleshoot your issue.
CUCM Version
EXP C and E Version
Type of Voice gateway and Signaling protocol adopted.
That could be a starting point :)
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo
I am using CUCM 10.5
Expressway C and E ver 8.2
Voice Gateway 2921 and Signaling protocol H323
Thank You
Hi Muhammad.
As asked from my buddy Deji, we also need logs from you VG and CUCM to investigate further.
Please start to post your vg running config, a debug voip diapeer inout.
Carlo
Hi Ayodeji Okanlawon ,
I also encounter this problem when using some Jabber client the call will drop after 2 rings, my Question is how should i check if i have a MTP resource on my Call manager? also just for a validation if i restart my Gateway is there any downtime would happen ?
Thank you so much appreciate your help.
MuhammadSaad_2
Hi Ayodeji
Thanks, as per your instruction i change and its working fine!!!.
