Showing results forĀ
Search instead forĀ
Did you mean:Ā
Jabber on IOS and Calendars
jzetterman
Does the Jabber app on iPhone only support integration with the Apple Calendar? We use Google G-Suite for email and calendaring and some users don't sync their G-Suite calendar with the Apple Calendar app and instead use the Google Calendar app. From Windows I can configure Jabber to use my G-Suite calendar, so it seems reasonable that I would be able to do the same from the iPhone app.
zeuscyril
Level 4
Level 4
hi
you can play with jabber-config file and see . i have not tried it but just an idea
