Jabber open directly with windows credential
nicanor00
I have cucm 12 and jabber
When I open jabber, it open directly with windows account login credential
For exemple my windows crediential is mike and the domain is abcd.com
When I open jabber, it open with mike as username and without the domain @abcd.com
I put the password it doent work
I tried to connect with different username (bravo on the mike windows session)
But when I put bravo@abcd.com then jabber delete bravo@abcd.com and put mike
I reintialise jabber, it reinitilise but it keep mike  as username
So I cannot connect with other user account on the mike pc
Rajan
It seems like you have Jabber deployment with Single Sign On enabled (SSO). If you need to bypass that, you need to install Jabber using the procedure mentioned in the below link:
https://stack8.com/installing-jabber-to-bypass-automatic-login-using-sso/
Rajan
Please rate all useful posts by clicking the star below and mark solutions as accepted wherever applicable
