Jabber Pop up disable for call on hold
rizwan.muzaffar
HI All,
Will you please let me know if there is a way to disable the pop up window for Jabber when the call is place on hold from the config/.xml file?
This can be disabled from Jabber itself from Setting > Calls > Bring Call Window to the front: and selecting "Except When on hold" But I want to know if there is a way to disable for all the user's by default. Jabber.png
If there are, and I don't know if there is, you would find the value to use in this document. Parameters Reference Guide for Cisco Jabber 14.0
Response Signature
Thanks Roger, but these basic config does not give any option for this pop up. This become more trouble when you have a shared line and 2nd user get the pop-up for your call. If the 2nd person close this pop-up call get dropped.
Let's see if any of our other experts had encounter this issue.
If it's not listed as a parameter in the document it's not possible to make that specific customization in the configuration file.
Response Signature
