Java Error -Cisco Unity
salin subran
Visitor
Hi All,
I am facing an issue with recording WAV in Unity, when ever i tired to Play or record it says InitMMAppletInstance failed to get instance.
Java Version : Version 7 update 79
Internet Explorer : Version 11
Cisco Unity Version :7.1.5.30000-117
Please advise
Best Reagrds,
Salin Subran
8 Replies 8
Deepak Rawat
Try using this tool:
http://www.ciscounitytools.com/Applications/CxN/ATM/ATM.html
Deepak
- Rate Helpful Posts -
+5 to Deepak. I switched to this tool some time ago as I was too frustreted with dealing with Java compatibility issues when it comes to the Unity Connection applet.
Very Good tool, it works to me
Hi Deepak,
I have CUC 10.5.2
Would you be able to help for Directory Handler greetings wav file upload?
Java is not working and ATM has no option for Directory Handler greetings file change option.
Thanks for your help.
gudiwada.balaji@servion.com
Community Member
Hello All,
When I was trying to record message in CUC  but am getting error "initMMApplet: InitMMAppletInstance Failed to get instance""
Please help me out to fix the issue
Thanks in advance.
Did you try the tool that Deepak suggested above?
Hope the above helps,
gsotirop
I tried the tool but get an Unhandled exception error when trying to record.
Update from my end, I found a windows 7 computer that had not been updated and was able to get the play/record function to work.    This was after trying every other solution that I could find.
