problem with cisco ip phone 6945 with cucm 8.6.2
gevangelista
I've  the problem in object.
I' ve connected the phone to th switch poe.
The phone get an ip address from dhcp server but  the display remain blank and the phone is not registering on the cucm.I think coulde be a firmware uograde probleem.
Can you help me?
Thanks in advance
Giancarlo
2 Accepted Solutions
joe.lazzaro
Level 4
Level 4
SIP or SCCP? do you have a DN already assigned to the phone?
Output of the status messages from the phone would be helpful.
Hi Giancarlo,
We have the same issue on with this version of callmanager, when we configured a 6945 phone on sip it registered with no problems. all other types of phones we had dit register correctly with sccp.
maybe this is the solution for you problem.
I hope cisco will come soon with a solutions because the sip protocol is no option for us.(firewall)
did you also try to install the following cop file on the Callmanager TFTP servers:
cmterm-6945-qed.9-1-1-0.cop.sgn
HTH,
Edwin
6 Replies 6
Chris Deren
Do you have other models working? At the same location and on the same network segment?
Is the phone getting TFTP address? Is it configured in CUCM or are you using auto registration? What are you seeing on status messages on the phone?
HTH,
Chris
Hi Chris.
I've  150 iphone working on this cucm, but it's the first 6945 instalall are ok (tftp, auto registration and so on) but on the phone display doesn't appears nothing!!!!!!!
joe.lazzaro
Level 4
Level 4
Hi Giancarlo,
HTH,
Edwin
Hi Edwin,
I've solved the problem in  the following mode:
I've downloaded the   cmterm-6945-qed.9-1-1-0.cop.sgn and after the firmware file.
I've configured the cucm with this firmware and  a this poitn the phone has been registered.
Thanks for your help
Giancarlo
Can you send me this version, and example SEP......xml
cmterm-6945-sip.9-1-1-0.cop.sgn
