L3 bandwidth Queues for VOIP Traffic
TyrosAdmin
This might be more of a question for QOS, but it does have to do with voice, so I'll give it a shot here.    We're a callmanager 7 environment using skinny and mcgp.
I have a 4x T1 MLPPP WAN solution at my main site, and in case I decide to increase my bandwidth, I want to be able to keep my same bandwidth allocations for tiered voice and data.
My WAN provider will automatically set the QOS on the links the way I have it set up, but if packets are to drop, I'd rather them drop at my router than against the wan where I have zero visibility.
I want my allocations to be in 4 tiers.    Top Tier gets 40%, and the other three tiers get 20% each   Class1 is for voice, Class2 is for VOIP Control/MCGP/Skinny, Class3 and Default are for remaining traffic.
I did some research, and tried this config.   However, what I got on the Class3 was an error that after setting priority percent 40 and 20 on the upper two classes, that there was only 15% of bandwidth remaining.   Last I checked, 40 and 20 equaled 60, not 85.   There must be something I'm missing.
Here's the policy map I'm wanting to set for my WAN traffic.
policy-map DV-L3-OUT
  class Class1
   priority percent 40
   set dscp 46
  class Class2
   priority percent 20
   set dscp 32
  class Class3
   priority percent 20
  class class-default
   fair-queue
I would appreciate any feedback that anyone might be able to offer.
James
jasyoung
Level 7
Level 7
You don't really want to use "priority percent X" for anything except voice bearer traffic. Use "bandwith percent X" for your remaining guaranteed queues, including voice signaling traffic.
The default maximum reservable bandwidth value of 75 percent is       designed to leave sufficient bandwidth for overhead traffic, such as routing       protocol updates and Layer 2 keepalives. It also covers Layer 2 overhead for       packets matching defined traffic classes or the class-default class. You now       can increase the maximum reservable bandwidth value on ATM PVCs using the       max-reserved-bandwidth command.
Thats exactly why the third priority command threw an error.
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a0080103eae.shtml
Here's a mind map which I personally like
http://cciev.wordpress.com/2006/05/25/qos-for-wan/
http://www.mindomo.com/view?m=1aa303cf33751870d7cba78aef9e0386 (Thanks to  Arden Packeer)
You should go thru the above doc. ... or just use AUTO QOS
/divin
PS:Rate only useful posts.!
dijohn
Sample Config
int se0/0/0
bandwidth X
max-reservable-bandwidth 80
  class Class1
   priority percent 40
   set dscp 46
  class Class2
   bandwidth percent 20
   set dscp 32
  class Class3
  class class-default
   fair-queue
/divin
PS: Rate ONLY useful posts!
dijohn
Mark this as resolved if you have no more questions! I see redunant posts in to section on CSC
