Labeling Hunt Group Logout Button
Support Albakom
Level 3
Level 3
we use a 9.1 CUCM with 8961 IP phones in a Huntgroup.
I configured a Phone Button Template with a HLog-Button to Logout/Login in Huntgroup
Now we use a german localization. And the label of the button is to long, so there is an unaesthetic  and grammatically wrong line break at the display (see picture).
Is there any possibility to change the label?
Jaime Valencia
This is something you would need to discuss with tour SE/AM, so they can bring this up with the localization team and its properly addressed
java
if this helps, please rate
Discussing with a AM to present Cisco its own errors - I can talk in vain.
Thanks to Cisco for the Betaproducts!
I'm sorry you feel this way, but unfortunately this is not something you can fix yourself, nor anyone else.
That info comes from the language pack, and that's built by the localization team.
You can also try opening a TAC so they file a defect against it, but in any case, it will be some time before the fix is implemented.
java
www.cisco.com/go/pdihelpdesk
java
