Last registration report for IP Communicator (CUCM 6.1)
Does any one know how I can extract a report that shows the last time an IP Communicator was registered on CUCM?
I already tried on the RTMT but it doesn't helps because it is able to show only IP Communicator devices that are currently in registered status or "unregistered" status. But has soon as the IP Communicator goes in "unknown" status the RTMT is not able to show the last time the device was registered.
Thanks in advance for your suggestions.
Best regards
Gabriele
Jaime Valencia
There is no record of that as such, you could get the info from the app log as there will be an unregistered event when the phone shuts down.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi all,
Does anyone have a solution for this post with CUCM 10.5 ?
Is there a way to run  a report on the last registration for IP Communicator ?
Thanks in advance !!!
Danny
