12-11-2017 07:37 AM - edited 03-17-2019 11:45 AM
Hi, I have several ldap directories, one of them is inactive that OU was decommissioned while ago but it was not deleted from CUCM. Now it looks like it's causing high cpu usage by trying to sync with ldap at night.
I want to delete that entry from cucm , BUT is it possible to check if there are users associated with that ldap dir?
Solved! Go to Solution.
12-11-2017 08:28 AM
If the OU doesn't exist anymore, or if it's empty, then you're not syncing any users from it.
12-11-2017 08:28 AM
