02-23-2013 03:45 AM - edited 03-16-2019 03:54 PM
Dear All,
I am running CUCM 8.6.
I need to sync my CUCM with Active Directory 2003.
I need to know what information do i need from cutomer to fulfill this task:
For example what should i have to configure in below fields:
Kindly let me know the re requisite to integrate CUCM with AD.
I will be very thankful to you.
Mukarram.
Solved! Go to Solution.
02-23-2013 04:51 AM
Hi Mukarram,
Here you go:
LDAP User Search Base | Enter the location (up to 256 characters) where all LDAP users exist. This location acts as a container or a directory. This information varies depending on customer setup. |
All 3 things would be needed from your customer to be able to set it up correctly. HTH.
Harmit.
02-23-2013 06:28 AM
Mukarram,
In addition you need to ensure the Distinguished user format as well as the search base format needs to be in LDAP query structure such as:
CN= ldapuser,OU=Test,,DC=internal,DC=domain,DC=com
You can use tools such as softerra ldap browser to find out the required string.
HTH,
Chris
02-24-2013 06:46 AM
Tiger,
You can also use that format for the distiguinshed name. It will work because that user exists in that domain..its similar to this format...CN=xyx, dc=xyx, dc=com...thats same as xyx@xyx.com
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
02-23-2013 04:51 AM
Hi Mukarram,
Here you go:
Harmit.
02-23-2013 06:28 AM
Mukarram,
HTH,
Chris
02-24-2013 05:14 AM
thanks everyone
I put
Distinguished use as xyx@xyx.com
then it worked....how it worked i still dont know
02-24-2013 06:46 AM
Tiger,
03-06-2013 01:17 PM
thanks aokanlawon....thanks alots for to the point answers...really appreciate...
