09-23-2024 11:39 AM
Hello
how i can change the all LDAP users Synched with AD to local users at once in CUCM V14
Solved! Go to Solution.
09-25-2024 03:06 AM
i used below Command and convert all users to local
run sql update enduser set fkdirectorypluginconfig=NULL where fkdirectorypluginconfig IS NOT NULL
09-23-2024 12:14 PM
Hi @omarahmed,
If I understand correctly, you are looking to convert all LDAP synced users to local CUCM users. If this is the case, then you you can use BAT tool to convert them to local users and then disable the LDAP or delete the LDAP related configuration.
09-23-2024 10:37 PM
Hello Vaijanath,
I wanted to inform you that there is no option available to change the users from LDAP to local. Please see the image below for reference.
09-24-2024 12:38 AM
I think that you'd need to use the Export/Import option in Bulk for this as it is not available in the Query option.
09-25-2024 03:06 AM
09-25-2024 05:27 AM
I’ve used this command a few times, but if I remember correctly, running it multiple times on the same cluster has caused issues. Be cautious, as you’re directly modifying the tables in the database. Ensure you have backups before executing any SQL commands
