12-04-2021 09:58 PM
Greetings,
I am wondering if someone could point me to some documentation, tutorials, or PDF's regarding how Cisco's IP Phone system works? I can find how to set it up but I can't seem to find how it works or why it works. If someone could point me in the right direction I would be very appreciative.
Thank you,
michaeltownley7
Solved! Go to Solution.
12-05-2021 01:47 AM
not sure is this help you : but check CVD :
12-05-2021 01:47 AM
12-05-2021 04:54 AM
@balaji.bandi +5, the cvd its a very good documentation.
@michaeltownley7 after you take a look at the doc provided you can schedule some collaborations labs using Dcloud or sandbox
https://developer.cisco.com/docs/sandbox/#!collaboration/collaboration-sandbox-highlights
12-05-2021 01:12 PM
@balaji.bandi @Leonardo Santana Thank you both for the information. The documentation provided from @balaji.bandi seems to be what I am looking for and I will definitely check out those labs @Leonardo Santana. But if I have any other questions I will be sure to ask again. Thank you both again for the information.
