Licensing for 9971,7965,7911 on CUCM 8.6
syed.shameem1
We are suggesting IP Telephony Solution for a client who has 1157 users.
Cisco 9971 IP Phones--- 40
Cisco 7965 IP Phones--- 117
Cisco 7911G IP Phones---1000
So kindly let me know what all licenses should be given to get the phones up and running.
CUCM 8.6
Server: MCS 7835 or UCS C200 M2
Awaiting for a early response!!
Thanks & Regards,
Eng Shameem Syed
2 Accepted Solutions
Adrian Saavedra
Level 7
Level 7
CUCM 8.6 is under UCL licensing. Those phones mentioned above are Enhanced, so you need to purchase 1157 UCL Enhanced licenses.
Hope to help, please remember to rate helpful posts.
Kind regards,
- Adrian.
Just use the UCL part numbers. You don't have to use DLU part numbers anymore.
Good luck!.
- Adrian.
6 Replies 6
nikshah
For the phones
9971 consumes 4 DLU per phone so 40*4=160
7965 consumes 4 DLU per phone so 117*4 = 468
7911 consumes 3 DLU per phone so 1000* 3 = 3000
Total DLU (Device License Units) = 3628 take a 10% ovehead so approx 4000 DLU's
I would recommend 3 node licenses for a 3 server configuration Pub and 2 subc and you would need a SW feature license for the number of nodes where CCM service would be activated.
Hope this helps
Niket
Kindly rate useful posts!!!
Adrian Saavedra
Level 7
Level 7
Kind regards,
- Adrian.
Hi Adrian,
Thanks for the information..
So "1157" of "LIC-CUCM-USR-B"  are enough or I should also go for device licences. If yes then kindly let me the part numbers of Device Licences.
Appreciate your help & Support..
Thank you,
Shameem Syed
Good luck!.
- Adrian.
Thanks Adian
hello I would like to know how many licenses use the following phone model Cisco 8811 8821,7925,7911, 7961
