06-21-2013 11:06 AM - edited 03-16-2019 06:01 PM
Dear Folks,
I am proposing a client for CUCME router that support 100 phones . Now my concern is while ordering phones should we order phone with licenses or is it already included in the CUCME that supports 100 phones.
Thanks for your support.
SID
Solved! Go to Solution.
06-21-2013 02:20 PM
You will need to order the licenses with your CCME. Depending on which bundle you purchased you will need to add additional licenses. if you have the 2900 ISR routers they come with a 25 seat license. Then you need to add 75 more seat licenses..
The part number you need is
FL-CME-SRST-25 ( you will need 3 of this) to make upto 75 seats.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
06-21-2013 09:24 PM
Just to clarify, you need both CUCME AND phone licenses.
The CUCME license is the "server" side license. As well as this, you also need a license for each handset - the "client" side license.
Barry Hesk
Intrinsic Network Solutions
06-21-2013 02:20 PM
06-21-2013 09:24 PM
Barry Hesk
06-21-2013 11:18 PM
Thanks for the queries.
So to clarify, to order every IP phone, there should be user licenses to be purchased separately .
1. is it applicable for 6900 phones, as i dont see it in the pricing , only 7900 phones is avaialble..
can you please advise.
SID
06-22-2013 04:06 AM
Correct. Every IP phone requires a license including 6921s.
SW-CCME-UL-6921= | Cisco Communications Manager Express License - 6921 IP Phone |
SW-CCME-UL-6941= | Cisco Communications Manager Express License - 6941 IP Phone |
SW-CCME-UL-6961= | Cisco Communications Manager Express License - 6961 IP Phone |
SW-CCME-UL-6901= | CCME PHONE LICENSE FOR 6901 IP PHONE |
SW-CCME-UL-6911= | CCME PHONE LICENSE FOR 6911 IP PHONE |
Barry Hesk
