02-08-2016 10:40 PM - edited 03-17-2019 05:48 AM
Hello .
I have problem with Lifesize.
I try to register device to CUCM and
device unregistered.
when I use X-Lite I was able to connect .
my version CUCM 10.5.2 , I define device as Third-party SIP Device (Advanced) .
any idea?
02-08-2016 10:54 PM
Are you sure everything seems good in configuration?
Possible to get SIP traces (REGISTER and appropriate response) to see what exactly going on?
- Vivek
02-08-2016 11:04 PM
1.yes, all configuration is good .
2.how to collect logs for sip ?
02-08-2016 11:10 PM
Is there any provision in lifesize to get SIP traces? Otherwise, you can enable SIP traces under Serviceability and get it using RTMT.
- Vivek
02-09-2016 05:22 AM
I had a similar issue a few days ago with a 3rd party sip device. Here is what you need to check
1. Configure a digest user and associate this to he phone
2. Configure digest credentials. Ensure your credential is complex.
3. Configure the digest credential on the lifesize device as well as other parameters.
If you still have issues collect cum traces as Vivek has mentioned..
Please refer to the link below to know how to collect logs
https://supportforums.cisco.com/document/12724111/understanding-cucm-traces-end-end#Collecting_CUCM_logs
