List DN's/Extensions VG224
Stuart McGrath
Is it possible to list all the extensions in one place on a VG224 from Call Manager (8.6).?
I find various methods to list the ports but no extension /DN details. No Dependency record option from the Main VG224 page.
6 Replies 6
Hi.
On gateway page , on find filter, select  DN/Route Pattern as filter and click find
Carlo
Please rate all helpful posts "The more you help the more you learn"
I've done this an no extensions are listed against the ports?
Hi.
Which protocol did you use to integrate VG with CUCM?
Let me know
Carlo
My mistake. I was hiding the endpoints. Frustratingly though the extension column disappears when you add a filter by description!.
I have exported the gateway details and this did the trick.
Stuart
Here what I meant
Carlo
Thank you a bunch, Carlo. You saved me hours of digging it out. Greatly Appreciated.
