List DSPs in gateway
Gordon Ross
Level 9
Level 9
How can you list the DSP modules in a gateway without opening up the box ?
GTG
Please rate all helpful posts.
2 Accepted Solutions
abukuru95
Level 3
Level 3
hello,
you can use the "show voice dsp group all"
and the "show diag" to have all the hardware on the platform.
good luck
please do not forget to rate this !!!!!!
Marwan ALshawi
also you can use show diag
then you will see all the hardware insstaled in your router in cuding VIC/WIC/NM PVDMs cards and its DSPs
good luck
if helpful Rate
abukuru95
Level 3
Level 3
hello,
good luck
show diag is the best option, as it clearly shows the model & channel allocation of the DSPs. (e.g. PVDM3-16)
show dsp group all is OK, but doesn't give easilly what I'm after.
GTG
Marwan ALshawi
good luck
if helpful Rate
