List of IP Phone Support Recording with Engage Recording Server
asherif82
I have a project whereas Engage Recording System will be integrated with UCM 10.5, However I'm trying to find the list of supported phones that can be able to record dual streaming specially for the following phones:
7975
7945
7841
8831
7926
Please advise.
Jaime Valencia
You can look at the phone specs to see if they have BIB, or run a report on CUCM for that.
java
if this helps, please rate
Jonathan Schulenberg
The report Jamie is referring to is under Cisco Unified Reporting > System Reports > Unified CM Phone Feature List. You would choose Product: default, Feature: Built in Bridge.
Here's the output from a CUCM 8.6.2 cluster:
Product Protocol Feature Parameters
Cisco 6911 SCCP Built In Bridge
Cisco 6921 SCCP Built In Bridge
Cisco 6941 SCCP Built In Bridge
Cisco 6945 SCCP Built In Bridge
Cisco 6961 SCCP Built In Bridge
Cisco 7906 SCCP Built In Bridge
Cisco 7911 SCCP Built In Bridge
Cisco 7921 SCCP Built In Bridge
Cisco 7925 SCCP Built In Bridge
Cisco 7926 SCCP Built In Bridge
Cisco 7931 SCCP Built In Bridge
Cisco 7937 SCCP Built In Bridge
Cisco 7940 SCCP Built In Bridge
Cisco 7941 SCCP Built In Bridge
Cisco 7941G-GE SCCP Built In Bridge
Cisco 7942 SCCP Built In Bridge
Cisco 7945 SCCP Built In Bridge
Cisco 7960 SCCP Built In Bridge
Cisco 7961 SCCP Built In Bridge
Cisco 7961G-GE SCCP Built In Bridge
Cisco 7962 SCCP Built In Bridge
Cisco 7965 SCCP Built In Bridge
Cisco 7970 SCCP Built In Bridge
Cisco 7971 SCCP Built In Bridge
Cisco 7975 SCCP Built In Bridge
Cisco 8941 SCCP Built In Bridge
Cisco 8945 SCCP Built In Bridge
Cisco IP Communicator SCCP Built In Bridge
Cisco 3905 SIP Built In Bridge
Cisco 3911 SIP Built In Bridge
Cisco 3951 SIP Built In Bridge
Cisco 6911 SIP Built In Bridge
Cisco 6921 SIP Built In Bridge
Cisco 6941 SIP Built In Bridge
Cisco 6945 SIP Built In Bridge
Cisco 6961 SIP Built In Bridge
Cisco 7905 SIP Built In Bridge
Cisco 7906 SIP Built In Bridge
Cisco 7911 SIP Built In Bridge
Cisco 7912 SIP Built In Bridge
Cisco 7931 SIP Built In Bridge
Cisco 7941 SIP Built In Bridge
Cisco 7941G-GE SIP Built In Bridge
Cisco 7942 SIP Built In Bridge
Cisco 7945 SIP Built In Bridge
Cisco 7961 SIP Built In Bridge
Cisco 7961G-GE SIP Built In Bridge
Cisco 7962 SIP Built In Bridge
Cisco 7965 SIP Built In Bridge
Cisco 7970 SIP Built In Bridge
Cisco 7971 SIP Built In Bridge
Cisco 7975 SIP Built In Bridge
Cisco 8831 SIP Built In Bridge
Cisco 8941 SIP Built In Bridge
Cisco 8945 SIP Built In Bridge
Cisco 8961 SIP Built In Bridge
Cisco 9951 SIP Built In Bridge
Cisco 9971 SIP Built In Bridge
Cisco ATA 187 SIP Built In Bridge
Cisco Cius SIP Built In Bridge
Cisco Cius SP SIP Built In Bridge
Cisco DX650 SIP Built In Bridge
Cisco IP Communicator SIP Built In Bridge
Cisco Unified Client Services Framework SIP Built In Bridge
