IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5900 Views
  • 14 replies
Hi ,  i ahve cucm 10 with mgcp gateway 3925... it has 4 port fxo card..in which analog line is connected...incoming to line is ok..but wen dialing outside with line, it gives silence in begin and then busy tone and disconnect it..  what could be issu...
Amit23 by Level 4
  • 2340 Views
  • 22 replies
hello,  i am running version 9.x AQM for call recording with UCCX 9... i have arounfd 20 uccx agents and they can login to AQM webpage that is also called cisco workforce optimization:  http://10.236.10.10/cwfo is it any option for agents to change t...
Amit23 by Level 4
  • 294 Views
  • 0 replies
Hello, I'm just getting into Voice and trying to save Call Detail Records to the buffer of a 2800 series router running CME 8.6 with two 7940 ip phones.I have CME set up and I'm placing a call and connecting between two extensions after following the...
Resolved! ELM 9.1 Produst In
 I am running standalone ELM server. The IP if the CUCM got changed and now I get The Product Instance at the hostname/IP address has already been configured on this Enterprise License Manager. When I try to add the new server.Nothing shows up shows ...
miket by Level 5
  • 278 Views
  • 2 replies
Is it possible to pair an HTC DROID DNA (6435LVW - Andorid mobile device) to a Cisco 9951 via Bluetooth? It looks like the 9951 supports the the Hands-free and Headset Bluetooth profiles. When pairing, the 9951 does not see the HTC device. Thank you.
hhbalfour by Level 1
  • 707 Views
  • 2 replies
Resolved! ISDN q931
Dear Experts Our toll free number is mapped to a landline number from ITSP, when PSTN users dials the toll free number sometime they are routed properly to our  premises and sometimes it plays audio " number is not valid please chk the number and dia...
                   Hello, we have 99xx Phones which uses G.722 as Codec within CUCM 8.5.                   When i use Jabber for Windows Client 0.0.1 as softphone the codec is switched back to G711 (Call from Softphone to 99xx Phone)                 ...
mjuch by Level 5
  • 2282 Views
  • 4 replies
