List of IP/URL for Smart Licensing (Direct cloud access)
ShankarP
Hi Experts, can we restrict the CUCM 12.0 outbound https access to list of IP/URLs, for the smart licensing to function? Thanks
Jaime Valencia
URL : https://tools.cisco.com/its/service/oddce/services/DDCEService
java
if this helps, please rate
8 Replies 8
Jaime Valencia
java
Hi Jaime,
Can't open the link you shared. I am also looking for something similar. More so for Cat 9K accessing the smart licensing on Cisco.com. I believe the same whitelist should work for both Collab and Switching products.
That's the URL to which products communicate, not a link where the info is.
java
Any idea what IPs/subnets tools.cisco.com is using? thanks
Rahul Mane
Dear All,
Please help me on IPs for smartreceiver.cisco.com to allow access on firewall.
72.163.10.105
72.163.15.144
173.36.127.16
192.133.220.90
192.133.220.120
Amirhossein Mojarrad
++++ If you find this answer helpful, please rate it as such ++++
Hi Amojarra,
when I do a nslookup tools.cisco.com the result is: 72.163.4.38
when I do a nslookup smartreceiver.cisco.com the result is: 173.36.127.32
both are not in your list.. any idea?
Thanks in advance,
Wim
amojarra
Hi @wimhasselo
Yes the IP addresses are not fixed.
from DNS records for smartreceiver.xglb.cisco.com — NsLookup.io  I can see some other new IPs
