01-23-2015 03:59 AM - edited 03-17-2019 01:42 AM
Whats the diference between LoadID and ActiveLoadID in CUCM Reporting Unified CM Phones With Mismatched Load?
Leonardo Santana
Solved! Go to Solution.
01-23-2015 05:20 AM
Hi Leonardo,
As per my understanding the ActiveLoadID would be the firmware that is actually running on the IP phone , while the LoadID is the one defined on Device defaults or Phone Load Name setting on the phone config page. You can verify the same by analyzing LoadID and ActiveLoadID for one of the phones where they are not matching.
Manish
01-23-2015 05:20 AM
Hi Leonardo,
Manish
11-03-2023 09:39 AM
Does anyone know for sure that if a phone has a load specified at the device level (different than the device defaults) but the running code matches the device specified code, does it get flagged as a 'mis-matched load' ?
11-04-2023 05:08 AM
On phone page you should find active and inactive load if the phone firmware has been recently upgraded with the current available firmware on CUCM.
If you find active load only it means that the phone matches the leatest available firmware on CUCM or it has never been aligned due to a communication error with the TFTP
Carlo
