Local directory lookup in CME 9.1 with 9971 SIP phones
massimo.capra
Hi all,
someone has already successfully configured the "service dnis dir-lookup" command in CME 9.1 (latest IOS update) with 9971 SIP phones (latest firmware updates)?
The goal is to show the local directory name (with number) on incoming ISDN calls.
With SCCP phones (eg. 7911) work correctly.
Thanks.
Massimo
thorstenn
Level 4
Level 4
did you ever solved the problem?
sultan0583
Does Anyone has a solution to the mentioned problem ?
