03-08-2016 02:37 AM - edited 03-17-2019 06:09 AM
Dear,
Can any one explain these translation rule in detail especially Voice Translation Rule 2 ,
voice translation-rule 1
rule 1 /^0112997\(...\)/ /7\1/
rule 2 /^2997\(...\)/ /7\1/
rule 3 /^40858\([01234].\)/ /58\1/
rule 4 /^01140858\([01234].\)/ /58\1/
rule 5 /^01148483\(..\)/ /83\1/
rule 6 /^48483\(..\)/ /83\1/
rule 7 /^40858\([5-9].\)/ /58\1/
rule 8 /^01140858\([5-9].\)/ /58\1/
voice translation-rule 2
rule 1 /^1\(.......\)/ /01\1/
rule 2 /^5\(........\)/ /05\1/
rule 3 /^2\(.......\)/ /02\1/
rule 4 /^4\(.......\)/ /04\1/
rule 5 /^6\(.......\)/ /06\1/
rule 6 /^7\(.......\)/ /07\1/
rule 7 /^3\(.......\)/ /03\1/
rule 8 /^01140858\(..\)/ /58\1/
rule 9 /^40858\(..\)/ /58\1/
voice translation-rule 3
rule 1 /^01140858\(....\)/ /\1/
rule 2 /40858\(....\)/ /\1/
voice translation-profile DID
translate called 3
voice translation-profile incoming
translate calling 2
translate called 1
03-08-2016 02:45 AM
This rule will match all 8 digits number starts with 1 and if so, translate to 01 and last 7 digits of matched number.
This rule with match 10 digits number starts with 01140858 and if so, translate it to 58 and last 2 digits of matched number.
All other rules for voice translation rule 2 are similar.
- Vivek
03-08-2016 03:10 AM
Dear,
Can you explain this rule 2
03-08-2016 03:16 AM
You really need to look at below document in order to understand this yourself:
https://supportforums.cisco.com/document/31816/custom-made-guide-translation-rulesprofiles-and-some-common-uses
Any number starting with 5 followed by 8 digits will be replaced by 05 and last 8 digits of matched number
Deepak
03-08-2016 03:36 AM
thank you.
03-08-2016 03:48 AM
Deepak is right. It will be difficult to under voice translations if you go with specific examples. Follow the link suggested by him and try to get with all wild cards and manipulations techniques and it will be easy to understand the subject then.
- Vivek
03-08-2016 03:00 AM
Adding to what Vivek said, you can always run below command on the router to test the output of your rule as well:
test voice translation-rule <RuleNumber> <Number>
Deepak
