08-24-2012 09:45 AM - edited 03-16-2019 12:52 PM
Just a question, if you have Local Route Groups enabled and a calling search space routing a international call differently, which one takes precedence?
Solved! Go to Solution.
08-24-2012 10:48 AM
CSS will drive which route pattern is selected and if Local Route Group is going to be used. Basically:
Phone CSS points to Route patterns based on assigned Partitions
Route Pattern points to RL, the RL can be one that uses Local Route Group
If that is the case Local Route Group defined in the phone's Device Pool will be used
You can absolutely combine local route group routing with regular explicit RP/RL/RL, basically some Route Patterns can point to Local Route Lists/Group and other don't have to. If certainly fits in some deployments as I have don't it quite a few times.
HTH,
Chris
08-24-2012 10:15 AM
They are totally different things. Local route group helps you select a local gateway based on the RG in your device pool. CSS is CSS
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
08-24-2012 10:48 AM
HTH,
Chris
