Showing results forĀ
Search instead forĀ
Did you mean:Ā
Lock IP Phone CISCO
youness hafid
Please  give me solution, I use Cisco Phones and i want to lock with code pin some phone
Thank you
5 Replies 5
Hi Youness,
Glad to assist you and we are one of the solution provider for Cisco. We have a Phone Lock solution which meets yours needs. Please visit us at www.commsouth.com and you can contact me at prasana@commsouth.com.
Prasana
Regards, Prasana Kumar.P +919841027006
Vivek Batra
You can use either Extension Mobility or FAC/CMC to restrict outbound calls.
- Vivek
Deepak Rawat
http://docwiki.cisco.com/wiki/Endpoints_FAQ#Can_I_lock_my_phone.2C_or_require_a_PIN_before_making_calls.3F.3F
Deepak
You can check the solutions here as well:
http://www.commsouth.com/UCC-Applications.php
http://commsouth.com/downloads/PhoneApplications_XMLServices_Brochure_EN.pdf
Prasana
Jaime Valencia
I list several options here
http://docwiki.cisco.com/wiki/UC_3rd_party_vendors
java
if this helps, please rate
