Bookmark
Subscribe
6671
Locking Volume on 8851
svadmin
Is there a way to lock changing volume on cisco ip phone model 8851 ?
The issue we are having is that people keep changing the volume to very low, then when we are paging, they can barely hear the volume since it has been lowered,
As far as I know there are three volumes on the phone
1) when the phone ring
2) when we are talking
3) speaker
Is this correct ?
luis_cordova
Hi @svadmin ,
I found this in another discussion. If you have The Cisco CallManager Administration program, try with this:
Q.    How do I prevent the user from changing the ring volume and network   configuration on IP phones?
A. Users are unable to change the ring volume if you disable the Settings       Access parameter on the Phone configuration page. Complete these steps:
  1. From the Cisco CallManager Administration page, choose             Device > Phone, and click the phone for which you want to             prevent a ring volume change.
  2. Choose Disabled for the Settings Access parameter             under the Product Specific Configuration section.
When Settings Access is enabled, you can change the phone network       configuration, ring type, and volume on the phone. When you disable Settings       Access, the Settings button is completely disabled and no options appear when       you press the button. Also, you cannot adjust the ringer volume or save any       volume settings. The option Restricted is available in Cisco CallManager       version 4.1(3) and later. When you change Settings Access to Restricted, you       can only access User Preferences and volume settings. By default, Settings       Access is enabled.
luis_cordova
Hi @svadmin ,
HARIS_HUSSAIN
1) https://community.cisco.com/t5/unified-communications/informacast-override-volume/td-p/2779160
Informocast do not provide control over volume so your only option is to block volume control by disabling settings access.
2) You can disable settings access, by below page from device settings. This will block speaker volume from getting saved.
3) You can apply the same to multiple phones per model using BAT Tool
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
rosapamela
my cisco phone is stuck on a certain volume how can i change that without going through admin support?
