Log In/Out of hunt group in Jabber
bcullen
Is it possible to log in/out of hunt group in the Windows Jabber client.
Ideally is would be great to use presence to determine whether a user is available or not
5 Replies 5
Ayodeji Okanlawon
Barry,
No that wount be possible. You will need the login/logout softkey which is not available for Jabber
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
do you know if its possible to configure something like a feature code to preform this task
ON CM 9.0
Hi Barry.
Not on CUCM.
On CME you can map feature access code to achieve this.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_f1ht.html#wp1050226
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
You could use AXL to update the Logged into Hunt Group setting.
You may configure a Webservice to send the requests or even an UCCX script which can be dialed.
The UpdatePhone request provides the hlogStatus function.
https://developer.cisco.com/site/collaboration/management/axl/develop-and-test/documentation/latest-version/axl-soap.gsp
