logout and missed call notification
zeuscyril
Level 4
Level 4
hi all,
i have one requirement
i  would need login and logout feature for phones regardless of phone models and they must receive missed calls while they logged out also.
this is possible in cucm 10.5 which is installed on the BE6000
thanks
6 Replies 6
Manish Gogna
When user is logged out from extension mobility then the phone will not show the missed call for that DN associated with the device profile through which he logs in.
Manish
hi manish,
if they login again it can show missed calls ? or it cannot show at all.
You only get missed calls if the phone actually rings, there is no way to get missed calls for a EM profile which is not logged in.
java
if this helps, please rate
hi jaime,
is there any other option which gives missed call information with login and logout option.
thanks
cyril
No, this would be the same as if you somehow expected an un-registered phone to get missed calls notifications when you plug it in, there's no way.
java
Hi.
You probably need a 3rd party "phone lock" solution like this one - http://aurus5.com/phoneup/lock
