Long Distance Calls
mightyking
Level 6
Level 6
Hi All,
I make a call From New York to Paris, once the call is answered in Paris, I transfers the call to someone in Canada, Toronto and hung up the phone in New Yrok. The audio stream is now btw Paris and Toronto. My question is:
WHO IS GOING TO BE CHARGED FOR THE LONG DISTANCE CALL?
MK
5 Replies 5
kailash_sharma
Assuming PSTN connection is involved in making outgoing calls, I guess you would be charged as you made two outgoing calls actually.
Or if the scenario is different, please elaborate.
Thanks Kailash,
I know I made two long distance calls but I have disconnected both. My connection to the PSTN is released. Isn't it?
MK
No, because when you transfer with PSTN, a new call is made.
For this reason some administratorsprefer to block offnet to offnet transfers.
kailash_sharma
Basically there are 3 parties involved in the PSTN(off-net) call, 2 have just answered the incoming call.
Although you are not there in the RTP but PSTN connection is still established.
My 2 cents, someone else can also throw some light.
Kailash
Thanks Guys, I appreciate the replies.
MK
