Long distance dialing from CUCM
bkhanal1971
Level 3
Level 3
I have noticed that I am not required to prefix 1 anymore to dial the national long distance numbers from my UCM 8.6 environment. Earlier, if I forgot to prefix 1, a message would prompt me to dial 1 before the number to proceed with the call but now I no longer have to dial 1 before the number to reach any long distance numbers. Is it new thing in the carrier side or something is not configured right in my CUCM. There are no digit manipulations for called number in the CUCM side, not even digit stripping. Only place where digits are manipulated are in the h.323 gateway. Even in the gateway, all I see is that the outside access code of 8 (we use 8 instead of 9 due to massive 911 miscalls) is stripped.
We use client matter code (CMC) for call accounting purpose and all long distance calls should be accounted. Local 10 digit calls do not require CMC code for it to proceed.  Since we are not required to prefix 1 for the long distance calls, when somebody makes such calls, they are not prompted for the code. I am finding it difficult to pin point what/where things went wrong.
5 Replies 5
Chris Deren
This has nothing to do with CUCM version and strictly a telco thing.  Can you post the GW config and "debug isdn q931" if this is a PRI, if not PRI let us know the circuit type.
Chris
Here is the debug isdn q931 output and dial peers. Yes it is a ISDN PRI circuit.
1. Call from DC to NY goes through without 1
Gateway#debug isdn q931
Jan 24 23:35:11.422: ISDN Se0/0/1:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Jan 24 23:35:11.422: ISDN Se0/0/1:23 Q931: Sending SETUP  callref = 0x06AE callID = 0x85B1 switch = primary-ni interface = User
Jan 24 23:35:11.422: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x06AE
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98396
                Exclusive, Channel 22
        Calling Party Number i = 0x2181, '2028848000'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '2122431110'
Jan 24 23:35:11.538: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x86AE
Jan 24 23:35:13.090: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x86AE
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Jan 24 23:35:13.538: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8  callref = 0x86AE
Jan 24 23:35:13.538: %ISDN-6-CONNECT: Interface Serial0/0/1:21 is now connected to 2122431110 N/A
2. Call from DC to NY goes through with prefix 1
Jan 24 23:36:32.934: ISDN Se0/0/1:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Jan 24 23:36:32.934: ISDN Se0/0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 2028848000
Jan 24 23:36:32.938: ISDN Se0/0/1:23 Q931: Sending SETUP  callref = 0x06B0 callID = 0x85B3 switch = primary-ni interface = User
Jan 24 23:36:32.938: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x06B0
                Standard = CCITT
        Called Party Number i = 0x80, '12122431110'
                Plan:Unknown, Type:Unknown
Jan 24 23:36:33.038: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x86B0
Jan 24 23:36:34.738: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x86B0
Jan 24 23:36:35.138: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8  callref = 0x86B0
Jan 24 23:36:35.138: %ISDN-6-CONNECT: Interface Serial0/0/1:21 is now connected to 12122431110 N/A
Jan 24 23:36:35.138: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x06B0
Dial-peers pertinent to the calls. There is only one translation rule for modifying ANI and no other translation rules exist.
dial-peer voice 13 pots
trunkgroup PSTN
description ROUTE.LOCAL.CALLS.TO.PSTN
translation-profile outgoing 1
destination-pattern 8[2-9].........
forward-digits 10
dial-peer voice 14 pots
trunkgroup PSTN
description ROUTE.LONG.DISTANCE.CALLS.TO.PSTN
destination-pattern 81[2-9]..[2-9]......
forward-digits 11
When checked in DNA, calls are using the right Pattern, CSS, RL and SLRG.
Thank you,
Kindly send the translation rule configuration and ISDN PRI configuration. also confirm that the number u dailed with and without prefix is reached to same  destination.
It sure looks like telco is letting you make these calls, is this MEGACOM trunk by any chance? Could be because they see it as ISDN Type National and handle it properly.  Your best bet would be to contact telco to see why that is, if you feel this is a problem for you.
HTH,
Chris
Thank you Chris. I am relieved with your findings as I was begining to worry if I messed up something in the configuration in the UCM or gateway. I will contact Level 3 (our telco provider) to fix it unless they charge us flat rate for both local and long distance numbers. In the worst case, I may have to create a bunch of route patterns for long distance numbers with CMC requirements.
Thank you again.
