Long reboot time on (IBM) MCS 7835 CUCM 7.1.3
bsugamele1
Level 4
Level 4
Hello Netpros....I have a 3 server cluster of IBM MCS 7835s running CUCM 7.1.3. Each server takes just under 30 minutes to do a full restart. The servers POST quickly...it's the CUCM services that seem to take a long time to start. Has anyone else experienced this?
This seems quite excessive to me as my UCCX servers running Windows on the same hardware take about
5 minutes to reboot.
Thanks!
Brett
2 Accepted Solutions
William Bell
You may be running into the following defect:
Resolved CUCM Caveats in 7.1(3b)su1
CSCtc80749 : Server boot up time increases with every reboot
This was a defect affect 7.1.3 and supposedly fixed in 7.1.3b-su1.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Good call from Bill on that bug.  Check on that for sure.  High 5 (points, that is) on that.
Also, just to expand on your boot time.  Outside of this bug, the service start times on the Linux platform IMO are generally slow as a rule.  Particularly, the Tomcat service is a dependency for many of the other services and it's the "turtle" when it comes to startup times.  Once it's in a Started state, the other services all come up very quickly.
6 Replies 6
William Bell
HTH.
Bill
Thanks for the replies. These servers were built on 7.1.2 and then upgraded to 7.1.3 so this could be the cause. I have scheduled the upgrade for Monday from 7.1.3.10000-11 to 7.1.3.32900-4. Hopefully that will speed up reboot times. I'll report back after the upgrade. Thanks again!
Brett
Brett,
With that new information, I think it is even more likely you are hitting this bug. The symptoms were noted when upgrading from 7.1.2 to 7.1.3. Definitely let us know what you find out after upgrading.
HTH.
Bill
Yeah I should have checked the Bug toolkit first. Thanks again William. BTW, I enjoy reading your blog. Keep up the great work!
Brett
Brett,
Thanks for the kudo. I am glad you like the blog, speaking of which I have some notes I need to put together to add some content.
Thanks again!
