you must contact a Cisco partner for initial orientation, otherwise you will never be able to complete the task yourself. Basically with Cisco your choices are between CUCM and CME, I would recommend the latter.
I'm not aware of any rule prohibithing that you contact suppliers, The US Gov. and Military contact and buy from vendors every day and cannot assume you are skilled in designing voice systems without a previous training that can last few years.
