Manager
bmoskal
I have acquired a set of 7940g IP phones.  I am running them POE and need help for my Voip provider to reprovision the IPs.  Calls/emails to Cisco state the service period ended for this model 7/31/2015.  The Voip IT tech needs access to the access the configuration of the units to provision.  The DHCH and IP addresses reflect the correct addresses.  However, they state they cannot associate the two.  Any suggestions how my guys can access the phone?
Manish Gogna
If you are looking for instructions on how to get into the menu on the IP phone to change the network settings then you can check the following post
https://learningnetwork.cisco.com/thread/5253
When you say "Any suggestions how my guys can access the phone?" , what kind of access are you referring to and what exactly are the settings that you are trying to change.
Manish
- Do rate helpful posts -
My Voip tech wants to change/update the SIP settings.  Any help there?
