Showing results forĀ
Search instead forĀ
Did you mean:Ā
Mapping Outbound Calls to Unique FXS/FXO Ports
ayyoubira
hi
I need a sample configuration for Mapping Outbound Calls to Unique FXS/FXO Ports
Jitender Bhandari
this would answer your question.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/41887-specific-fxs-call.html
JB
Please rate helpful posts.
Jitender Bhandari
JB
thanks for de help
you can mark the post as answered if you dont have further questions.
JB
Nadeem Ahmed
 You need to create dial-peer with destination pattern of number you need to match for outbound calls and associate respective port number of FXO line
example
dial-peer voice 10 pots
destination-pattern 94087847430 (destination pattern can be common or number pattern which is going to match this dial-peer)
port x/y/z
FXS generally used analog phone line again you have to create a dial-peer with pots x and associate FXS port number for receiving call.
Br,
nadeem
Br, Nadeem Please rate all useful post.
