MATRIX SPARSH VP110 Business IP Phone and CUCM
Sonam
HI,
Can we use MATRIX SPARSH VP110 Business IP Phone with CUCM 11.5? if yes, please help me with configuration link.
Thanks.
Jaime Valencia
Cisco doesn't test 3rd party phones, if it uses standard SIP, it might work, config on CUCM is the same, documentation covers it. Config on the device is up to you.
java
if this helps, please rate
