max participants on meetme call on call manager
@Syed
Level 3
Level 3
Hello All,
I have setup up meetme conference, and change meetme participants capacity to 48 but only 15 - 16 participants can join and 17th one is getting busy tone.
Is this expected?
I'm running on cucm 8.5.
Jaime Valencia
What are you using for CFB? and does it support 48 streams/conferencees?
java
if this helps, please rate
thanks for your reply.
No, I do not have CFB but the default ones. I have 2 nodes in the cluster.
