Max Phones Exceeded
Davemzcs2
I have a CME with a 100 phones Permanent licence i am only using 38
I registered one SCP phone and then one of the other phones got the message "Max Phones Exceeded" on the screen.
The Max ephone and Ephone Dn is set to the top -allowed by the CME- which is 138 and 600 respectively.
the "show ephone" output for that specific phone is showing the "DECEASED" status
Do you guys know why this could be happening?
6 Replies 6
Jaime Valencia
Are you using that device for something else besides CME??
Everything that you do in the ISR requires resources, if you're already using that ISR for a lot of things, you might not have enough resources for everything.
java
if this helps, please rate
Hi Jaime!
I am using a Cisco Configuration Assistant to check the device's Health, and it's just fine.
Besides, i am just using it for Telephony purposes
Aseem Anand
Please share the output of show license detail cme-srst, show version along with the running configuration.
Aseem
Firstable, i made a mistake reading the license information before i think. it's not 100 users it's 30 users.
show license detail cme-srst:
"name#show license detail cme-srst % Error: No license for cme-srst found - License feature not found"
Show Version:
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 14-Feb-13 10:17 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)XA3, RELEASE SOFTWARE (fc1)
UC_560_Bquilla uptime is 26 weeks, 5 days, 17 hours, 16 minutes
System returned to ROM by reload at 19:01:13 PST Wed Apr 6 2016
System restarted at 19:01:45 PST Wed Apr 6 2016
System image file is "flash:uc500-advipservicesk9-mz.151-4.M6"
Last reload type: Normal Reload
Last reload reason: Reload Command
export@cisco.com.
Cisco UC560-FXO-K9 (MPC8378) processor (revision 0x100) with 497664K/26624K bytes of memory.
Processor board ID FGL162412TF
MPC8378 CPU Rev: Part Number 0x80C4, Revision ID 0x21
30 User Licenses
4 Gigabit Ethernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
I am not allowed to paste the running config
Then it means you do not have sufficient licenses.
Aseem
Well here's the weird thing:
i have licenses for 30 devices and check this out:
show ephone | count ephone
Number of lines which match regexp = 30
One of the Ephone is DECEASED:
ephone-42[41] Mac: ****.****.**** TCP socket:[-1] activeLine:0 whisperLine:0 DECEASED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:12
IP:***.***.***.*** * 1024 SPA502G  keepalive 42 max_line 1 available_line 1
using default button layout
button-layout 1: line button 1: cw:1 ccw:(0 0)
  dn 42 number *** CH1   DOWN         CH2   DOWN
Preferred Codec: g711ulaw
Lpcor Type: none Username: ***** Password: ****
Just 29 are Registered:
hostname#show ephone registered | count ephone
Number of lines which match regexp = 29
This is what i tried:
i deleted the ephone dn and the ephone # it had before, created a new one with the same MAC address and same number.... and did the same process all over again and created a new one again with a different number and same MAC
