Maximum number of routepatterns a callmanager can load
sirajuddeen t p
Dear All
I have a callmanager cluster which have 1 publisher and two subscribers. I want to creat 1413 route patterns and 720 routelists to reach other gatekeeper connected sites. CallManager version is 4.1.3. Please advice me, whether I can configure these number of routelists and patterns in the callmanager cluster. Is there any limitation for configuring route patterns and routelists? Will it affect the normal function of Callmanger process? We are using 7825H2 MCS servers.
Best Regards,
Siraj
Jaime Valencia
There are no hard limits as it depends on HDD space and many other factors, as long as you keep a clean dial plan and make good use of CSS and partitions there should be no problem with that amount of elements.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
