Media Termination Point - Disable
UsmanAkram1525
Hi Experts,
I am facing an issue with MTP.
We are using GSM based calling with CUCM and there are 2 different scenarios with MTP:
1- Media Termination Point required option is enabled in SIP trunk :
if called number is invalid or Power off so I get a proper response like ISP IVR (the number you are dialing is invalid or power off)
2- Media Termination Point required option is disabled in SIP trunk :
if the called number is invalid or Power off so my dialer keeps ringing and drop the call after 32 sec automatically.
We want to disable the MTP option in the sip trunk but getting issues in 2nd Scenario.
Please suggest
Thanks.
Jonathan Schulenberg
What does the SIP dialog look like for the working and non-working scenario? What’s different?
