Media termination point required
elite2010
Level 3
Level 3
When Media temination point need to be checked on the trunk configuration .
I have sip trunk , is connected to another sip (non cisco) , in that case do I need  check media termination point required ?
Jonathan Schulenberg
(climbs on soapbox)
I suggest never ticking MTP Required. If it fixes a problem it’s almost always a bandaid instead of the real solution. It doesn’t scale and is likely to create as many problems as it solves.
These settings on the SIP Profile are usually the correct solution instead of MTP:
- SIP rel1XX Options: Send PRACK if response contains SDP
- Early offer support for voice and video calls: Best Effort (no MTP inserted).
- Enable SIP Options PING.
If the call fails with those choices you would need to debug the call and see what happens in the SIP dialog between CUCM and a 3rd party system. If it’s something CUCM doesn’t support the solution would be an SBC such as CUBE between the two systems for interworking.
