04-03-2007 12:47 AM - edited 03-14-2019 08:48 PM
At 11:22:25 on 04/03/2007 on cluster CCMSERVER-Cluster.
Number of MediaListExhausted events exceed 0 within 60 minutes
i am getting the rtmt alert from my callmanager kindly provide the solution to relove this issue
thanks in advance
sunny
04-03-2007 01:56 AM
there can be multiple reasons why ur getting this error. Once of the most common reason for this to happen when you have still not exhausted the resources is you have a device pool which does not have access to the resource. For example, the phone is trying to request MoH with codec of g729, but the MoH server only supports G.711, this would cause an issue and the alert to be generated. Go to IP Voice Media Streaming Application Service Parameters configuration and select all codecs for MoH Audio Format and then restart IPVMS service and see if this resolves the issue
04-03-2007 11:17 PM
hi mchandak
very very thanks for the help. The server is in production
so in the week end i can configure and restart the server and let you know the status.
