12-11-2015 10:02 PM - edited 03-17-2019 05:12 AM
Hi Guys
I wanted to try mediasense in my lab. Tried installing the 8.5.4 on VMware workstation 11 using the ova template from cisco. Installation was fine. But was unable to get the login page. Tried restarting the Cisco Tomcat service. no luck.
Also I am unable to ping the ip address of the media sense server.
During the boot i get mount point error(attached image).
Tried to run a diagnosis and got error on Tomcat sessions.
Any suggestions?
Thanks in advance.
Solved! Go to Solution.
12-12-2015 04:32 AM
Hi Krishna,
As per the Mediasense design guide for version 8.5(4) "Cisco MediaSense may only be deployed on top of a VMware hypervisor, which must be running on a Cisco B-series server with fiberchannel-attached SAN storage (for at least the first two disks), or a C-series server with directly attached hard disk drives, or a Services-Ready Engine (SRE)."
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/mediasense/854/srnd/cms854srnd.pdf
Manish
12-12-2015 04:32 AM
Hi Krishna,
Manish
12-12-2015 10:21 AM
Thanks Manish for the response. Can any other version of mediasense be installed in lab(on pc) ?
12-12-2015 08:40 PM
All the UC products are meant to be used on ESXi, nothing else, you *might* be able to run them on other options, but we have no official support, nor expertise on doing such, depending on what you want to test in your lab, you should be running a supported environment, like the one that the customers are running, you won't find customer running over workstation.
12-13-2015 12:33 AM
Hi Jaime
Yeah I get it. I was wondering if we can install mediasense as Cucm and unity on other platform like workstation.
Thank you.
