05-07-2015 05:15 AM - edited 03-17-2019 02:55 AM
hi all,
i am using meet me conference with the user authentication using Cisco unity connection.
after authenticating the user the call is transferring to the meet me once it is joined it is disconnecting immediately.
while i am trying internally with extensions it is working. but when we use from mobile to reach meet me via analog line i am facing the disconnection issue.
my call manager version is 10.5 and CUC is 10.5 and voice gateway also 10.5
i am attaching the errors which i am getting
voice call debug
*May 6 13:34:23.303: Potential Mute Call:
*May 6 13:34:23.303: CallID1=9; CallID2=10; ConfID=5
*May 6 13:34:23.303: Leg 1: CallID=9; TX packets: 1082; RX packets: 894
*May 6 13:34:23.303: Leg 2: CallID=10; TX packets: 874; RX packets: 1082
voip rtp debug
ession information:: session=0x3F564C18 dsp_intf=0x3F572C80 dsp_name=0/1:1
*May 6 13:56:19.279: connections=2 streams=4 (7962 7961 7960 7959 )current sta te S_DSMP_VC_RUNNING current container simple_voice_container
State Transitions: timestamp (container, state) -- event -> (container, state)
2205.272 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2207.760 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_BEGIN -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2207.988 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2208.180 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_BEGIN -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2208.460 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2208.820 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_BEGIN -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2209.000 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2209.080 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_BEGIN -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2209.400 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2209.740 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_BEGIN -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2210.020 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2213.580 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_BEGIN -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2213.888 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2214.040 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_BEGIN -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2214.312 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2214.380 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_BEGIN -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2214.620 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2222.160 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_BEGIN -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2222.212 (simple_voice_container, S_DSMP_VC_RUNNING) -- E_DSMP_CC_PLAY_REQ -> (s imple_voice_container, S_DSMP_VC_PLAYING_TONE)
2222.448 (simple_voice_container, CNFSM_CONTAINER_STATE) -- E_DSMP_DSP_DTMF_DIGI T_END -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
2222.928 (simple_voice_container, S_DSMP_VC_PLAYING_TONE) -- E_DSMP_CC_STOP_PLAY _REQ -> (simple_voice_container, S_DSMP_VC_RUNNING)
2222.928 (simple_voice_container, S_DSMP_VC_RUNNING) -- E_DSMP_CC_STOP_PLAY_REQ -> (simple_voice_container, CNFSM_NO_STATE_CHANGE)
Packet suppression is disabled
DSP Encap: 0x1
Codec Mask: 0x4; Codec Bytes: 20
Fax Rate Mask: 0x2; Fax Bytes: 20; T38 nse Disabled; T38 sse Disabled
VAD Mask: 0x1
*May 6 13:56:19.283:
Stream information:: stream=7960
Type: PACKET, Direction: INPUT
Fax/Modem Type: voice
Xmit Function: 0x36521908
Xmit function is Enabled
Call ID: 20, Conference ID: 10
DSP slot: 0, DSP id: 0, DSP channel: 1
05-07-2015 05:29 AM
One thing that you can check is if the region settings between the gateway and cucm are the same as between unity ports and ip phones. It could be failing because of a codec mismatch which requires a transcoder.
Manish
05-07-2015 06:42 AM
hi manish,
here the codec configured on the gateway
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 g729br8
and in the cucm it default. is there any thing else to be checked?
05-07-2015 07:17 AM
Can you try hardcoding g711ulaw on the dial-peer and see if it works.
