MeetingPlace - Storage Location for Attachments
KRISTINE OBrien
How do I find out where the attachments for web conferences are stored in MeetingPlace?  I am running version 7.0.3
Kristine
dansmit
Hi Kristine-
There are two possibilities depending on your configuration.  Go into the MPWeb admin page->Shared Storage and see if it is enabled under step 1.  If it is, then your answer will be the "shared storage path" in step 1.  If it is not, then they will be in C:\Program Files\Cisco Systems\MPWeb\WebConf\content\7.
In either case they will be in a sub-folder with a unique numerical ID.  There are ways of finding out what the ID is, but chances are, it will be easier to sort the folders by timestamp and then look for the folder that is close to the meeting you are looking for.
I hope this helps
Dan
dansmit
Hi Kristine-
I hope this helps
Dan
That was it.  I found it under Shared Storage.  Thanks!
