IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5526 Views
  • 14 replies
this message apper when i try to call the AA pilot number:CALL_CONTROL-6-APP_NOT_FOUND: Application aa in dial-peer 1000 not found.  Handing callid 91 to the alternate appand this is my configuration:application service app-b-acd-aa flash:bacdprompts...
I have successfully setup a custom alert in RTMT, however I have run into a problem that I am hoping someone can help with.How can I set up the alert so it is based on the cluster rather than an individual server? As an example, I want to monitor tra...
Resolved! MWI port
All,Will a phone line (DN) need to reach the MWI port in order for MWI to work? Or just the MWI needs to reach the phone line (DN)? Or they both the phone line (DN) and MWI need to reach each other?Thanks!
yuhuiyao by Level 1
  • 450 Views
  • 3 replies
Hi, I have a request from one of my client to implement t an auto attendant in their location. The setup is running CUCME ver 7.1 and CUE ver 7.2. Please see the attached file for the requested call flow. My questions is about 1.     the busy prompt...
faizal_vi by Level 1
  • 259 Views
  • 1 replies
Resolved! Cisco CME 4.1
HiI have a gentleman who came to me for some help and i didn't want to steer him in the wrong direction on how to fix his issue.He is telling me that he was able to get CME installed but the translation rules aren't working. If you read below this is...
Unity connection 7 not attempting the user to sign into their mailbox when the messages button selected.  They get the default message from Unity Connection-Cisco Cathy.  It is acting like Unity does not recognize the extension to mailbox.  I have th...
grnelis by Level 1
  • 397 Views
  • 1 replies
I am trying to support a variable length dial plan where some numbers overlapPhone-A DN = 400Phone-B DN = 4005Is there any way for a 3rd user dial either of these numbers with out using a prefix and with out using long inter digit timeouts?thanks
