05-03-2012 07:00 AM - edited 03-16-2019 10:57 AM
We have a new Cisco 2951 ISR with CME installed by consultants a few months ago(due to my lack of knowledge and time). The system replaced an older 2801. The 2801 ISR would support either ad-hoc or meetme conferencing as i was told and now i suspect that was due to a lack of dsp's.
With the new system, the consultants setup a meetme extension and i'm positive we tested the meetme bridge successfully. . The problem is that people are trying to use adhoc conferencing and it does not work. The phone says Cannot complete conference. Meetme also gives error No Conference Bridge. Cisco tech says we need a dsp upgrade. I know at least meetme worked on this new system when installed.
We do have a few branch offices connecting to the isr over the Wan - these sites have 911 translations setup so that when they dial 911, the call comes back to us and goes out over a vonage phone line with their office address registerd. I cannot be positive we tested the meetme conference before this 911 testing was done. i think this would be the only explanation for not having enough dsp's but i could be way off.
What i'd like to do is get at least adhoc conferencing to work because no one even knows how to use meetme and adhoc worked on old system
Any help would be appreciated. This is the info on the dspfarm. please inform me of any other pieces of config you might need to help guide us in the right direction.
NOVA-CME#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : DOWN
Profile Operation State : DOWN
Application : SCCP Status : NOT ASSOCIATED
Resource Provider : FLEX_DSPRM Status : NONE
Number of Resource Configured : 0
Number of Resource Available : 0
Codec Configuration: num_of_codecs:6
Codec : g729br8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 1, Service = CONFERENCING, Resource ID = 2
Maximum conference participants : 8
Codec Configuration: num_of_codecs:2
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Total number of DSPFARM DSP channel(s) 0
05-03-2012 07:27 AM
Your profiles are down and not associated, review your configuration:
Associate the profiles and do a no shut on them.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-03-2012 09:02 AM
We also have two Call Park extensions setup that were not on the original system. Could we remove those to free up dsp's?
05-03-2012 09:05 AM
Call park does not use DSPs.
TDM interfaces, CFB, XCODER, MTP DO use DSPs.
java
05-03-2012 09:08 AM
Call park does not use DSPs. If you are running low on dsp resources th eonly thing you can do is to reduce your e1/t1 channel confugred. I wouldnt advise this since you are not a techie...
Can you post your
sh run
and a "sh sccp status"
05-03-2012 09:14 AM
Ran command no conference hardware to turn off the need for dsp's. now can do software ad-hoc conference.
Thanks for everyone's help.
