Meetme external caller disconnects
dan.letkeman
Level 4
Level 4
I am wondering if it is possible to have an external caller call into a meetme number via a DID or via a Transfer?  I have the meetme conferencing setup using Call Mangager 8.6 w/ 2901 as a hardware conference bridge, and it works with internal phone.  But when I try to use a DID and translate the call into a meetme conference number it connects, I hear the beep, and then the call disconnects.
Any suggestions?
Dan.
Jaime Valencia
Either option works, you probably want to debug the exact reason for the disconnect.
Make sure you're actually using the HW CFB with the right codecs enabled.
java
if this helps, please rate
Jaime Valencia
java
Adding to Jaime's point, just wondering what are the Codecs you have allowed for the Meet Me Conf?
This was the problem.  The device group didn't have the media resource group set, which in turn was not using the hardware conference bridge.
Wilson Samuel
Level 7
Level 7
Yes, it is possible to have External Callers be conferenced  into the Meet Me Conf.
However the Meet Me Conference must be set up Prior to the external call.
