Message pin not being recognised on CUE
rramlal
Hi All,
I have a customer that has a UC520 with cme 8.1 and cue 7.0.1. Recently an upgrade was done by an external party and now there is an issue where when users are accessing there voicemail the pin is not being recognised. It seems that the digits on the phone are not being recognised on the cue.
The auto-attendant is still working and users are able to leave voicemails.
Can someone advise what can be the cause for this issue?
Hi thanks for the logs.
You currentlyu have 2 DP to CUE with differnt DTMF.
You need to update one of the 2.
Please access the CUE and RUN 'sh  ccn sub sip'
Base on the output you need to modified the DTMF metho for DP 900 or DP 2001
Please Kudos/rate if this help!
6 Replies 6
Any way I can double check your sh run?
Make sure the Dial-peer you use for CUE has the
'SIP-notify' command
Please remeber to kudps
Please see attached the sh run of the cme
Please also see attached the cue sh run
islam.kamal
Level 10
Level 10
can you test the below configurtaion?.
dial-peer voice 6800 voip
destination-pattern 5...
session protocol sipv2
session target ipv4:a.3.6.127
dtmf-relay sip-notify
codec g711ulaw
no vad
if this is not working , please catch (debug ccsip messages) and share, please.
Thank you
please rate all useful information
Thank you Jose,
I verified the auto attendant dp was working fine and changed the voicemail dp to the dtmf relay to nte-rtp and this worked. I beleieve that the cme 8.1 versions requires this since before the upgrade it was working fine with ver 7.1.
Thanks again.
